Discuss tile trim around a window. in the British & UK Tiling Forum area at TilersForums.com.
brian c
I put trim inside reveal, can't get my head around the other way :dizzy2:.
some people like to tile to the highest point at the facing wall at the reveals (and get a run of cuts) and at the top an insert the trim to the face tile ...this way you lay the trim flat in the mitre block to nget your cuts.Hope this makes sense to you.
burncross
for those that use trim cutters, you have to put the trims on the wall instead of the reveals.As the mitres dont match up, because the trim cutters cut the trims laid flat, as opposed upright like mitre boxes :dizzy2:
doug boardley
that's why I use my trim snips for sharpening my pencils, about all they're good for imo!!
macten
1,158
Nottingham
You can still use trim snips for internal corners - just cut off a section of the flange and you can stand them up. Still, trim snips are cr*p and only use them for cutting trim straight and cutting Silicon tube nozzles.
Reply to tile trim around a window. in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Hi all, Have a question about how/when best to install tile trim - probably quite basic! One...
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
So, my elderly/disabled neighbour mentioned to me the other day that one of the seals had come...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
