Discuss tile trim in the UK Tiling Forum area at TilersForums.com.
bluebob
couple of brands about,if u have a local supplier who does genisis trim ask or some corners.easy to use,just cut trim sqaure in 3 directions and corner will fit into end of a trim.really neat. bright ideas have started to make similar product ,they sell em in packs of 2 if u dont do a lot of tiling.have used 6 and 8mm in white or cream.you,ll never mitre 3 way corners again:hurray:
andy-p
I cant remember the last time i used plastic trims , i dont mitre i use metal trims ,mostly the square edged ones ,they really look the business..:thumbsup:
Colour Republic
They shouldn't take that long, it's just getting use to it. I suppose if you don't do a lot of carpentry work it might take you a little longer to get your head around it but plastic trims are very cheap so easy to practice on, a little bit of sand paper works wonders if your walls are not a perfect 90 degrees
I don't think plastic trims do make a job look crap. All products have a time and a place especially if you are trying to hide the trims and not make a feature of them. I prefer aluminum but i'm not adverse to using plastic if the job calls for it
Reply to tile trim in the UK Tiling Forum area at TilersForums.com
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
tile trim
    Votes: 5 4.5%
    Votes: 8 7.2%
    Votes: 7 6.3%
    Votes: 32 28.8%
    Votes: 14 12.6%
    Votes: 28 25.2%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.1%
    Votes: 18 16.2%
    Votes: 13 11.7%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
