Tilemaster Anti Fracture Matting
Hi Lee,
No never seen that before.....looks interesting, what's the material like?.......and where do you purchase it from?......was chatting to another fixer today and he was recommending kerracoll anti fracture matting, didn't know they did one, I like to try different products.....what's the cost work out to per metre?
Cheers for the link
Where I am most of the uncoupling membranes are more or less in and around the same price depending on the quantity ordered, between £7-9 per mtr basically.
The above product imo was excellent, it was very thin, 0.7mm and flat, so used very little adhesive compared to Ditra. It's similar to BAL rapid mat which I've used loads of, although it has a composition like that a roofing membrane in that there is a mesh like structure to it through a fleece like material. When I had to remove damaged tiles I honestly couldn't believe how hard it was to do it. I used a Botament system from start to finish, primer, leveller, adhesive, mat and adhesive etc.
I was very concerned about the floor I had to cover and their technical director for Ireland met me on site and gaurenteed that if I followed his spec that it would not fail. Having utmost faith in Schluter I contacted them and went over the particulars of the job with them in detail and they said they couldn't do what Botament claimed they could and that they'd never even heard of the company, which by the way is global.
Botament told me that their membrane is so advanced that it's the way all membranes will eventually end up like and to be honest I can see why.
Sorry for the long post, but I wanted to give you the best feed back I could.
Ditra in my opinion is still the most effective option bar none.
Ok, it uses more adhesive - but that's part and parcel of it's design and function.
BAL RapidMat is incredibly similar to Wedi's subliner flex - aside from the colour - anyone else notice that?
Will definately give this stuff I try.......thanks for feedback Lee.........
Botament offered a solution to a particular problem that in this case Schluter wouldn't. I swear by Ditra, however this product was introduced to me as a solution for this particular problematic substrate. I was sceptical at first having never heard of it before, hence all the on site meetings with technical support before using it.
It was new to me and I have to say that I'm very impressed by it.
I take it you've used the product on large problematic substrates before Imp and that's why your saying that Ditra is always better. Each to their own, but I'm always willing to learn.
Would you continue using it Lee ?
Hi Lee,
What was the problematic substrate you tiled onto using this matting out of interest that Schluter couldn't guarantee??
Definitely, one other aspect of it that I really liked was that it really did stick like s**t to a blanket to the floor, it also has the 100mm grid lines printed on it as well as the overlap line. It's similar to BAL rapid mat but seems much much stronger, especially when removing damaged tiles and I think it bonds better to the floor
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
