Discuss Tilers Forums Hall of Shame.... in the British & UK Tiling Forum area at TilersForums.com.
AliGage
Subscribed
4,531
1,188
Peterborough, England
Just read through this thread and seen some proper horrors. Saw something like this a couple of times;
What is the correct way to do this sort of cut? would you go to the trouble of getting the system drained, removing the rad valve and drilling the tile?
Sometime this is unavoidable. But, in the picture you have there perhaps some biege Silicon for the cut marks instead of grout would of looked a bit better.
John Benton
1,138
Leeds
Yes, if you want it doing correctly.
If that's not possible I normally drill a hole where the rad stalk comes out of the floor, and then from the wall side of the tile I would do 2 cuts on the wet cutter in a V shape towards the hole. Then I would fix the tile in place and then slide the V shape cut out towards the pipe which closes the gap left by the cut of the wet cutter. Possibly fill any little nicks with same colour silicon.
I
Ian
Sorting out a shower cubicle at the mo, it's been leaking. It's a catalogue of errors but my favourite part is the tray. The opening is 90x80cm and the tray that had been used was 70x70, the area around the edge had a little shelf on it, not a problem I hear you say, well here's what I found when I started taking it apart
Two courses of bricks, not stuck by the way just placed in around the edge, covered with about an inch of skim, then the tiled shelf on top! Some how this lasted 10 years before it leaked, mind you, there were several tiles siliconed to the wall, I'd guess that a dozen tubes of Silicon had been used.
Sent via Tapatalk for iPad
Its becoming a regular monthly discovery. Builders, plasterers and plumbers who say they do the whole job but...well, you know the rest.
Today's gem is an 800 quad held in place by 1 screw only, no Silicon in the base of the wall plates and about 2 tubes worth under the front bar. Oh, and a lovely surprise water feature in the dining room when they used it for the first time. They only moved in on saturday.
Q
Qwerty
Another one for the collection- called by a couple to look at "settlement cracks" in the floor of their ensuite (it's ok though as that's what the builder told them might happen after a couple of years!!!! :yikes:)
I had to break the bad news to the customers that the cowboy fixing was to blame. The builder had laid the Marmox showerlay former directly onto joists with the rest of the floor (chipboard) tiled onto with NO tanking. The whole floor moves!!! I have never seen such a bad job
John Benton
1,138
Leeds
Jesus it's a wonder they didn't fall through that floor!!!!!
Reply to Tilers Forums Hall of Shame.... in the British & UK Tiling Forum area at TilersForums.com
  • Article
The UK Tiling Forum is a popular choice for tiling advice, with a large community of experienced...
I have had my ensuite and bathroom installed in April. The job had ongoing issues during the job...
Tilers Forums .co.uk is being used as a menu system to the main tile forums...
Tilers Talk Facebook Group Se connecter à Facebook Connectez-vous à Facebook pour commencer à...
Admin1
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
