Tiles coming off easy and net set.
Hi guys, I put up hardiebacker and primed with Ball APD 1:1 ratio at 2 coats. After that I applied 2 coats of Aquadefense.
I started tiling (30mm×10mm) tiles, using 8mm trowel. I did a few rows, and left it to continue the following day. I Continued with the tiling but, by the next few rows I was not happy with it so I decided to start over. So removed them last night.
To my surprise the rows I did the day before (which should be rock hard by then) came of super dupa easy, revealing what looked liked crumbly dry/ish adhesive with had not set.
Also, the Aquadefense seemed damp and when removed the hardiebacker seemed damp too, like it sucked the moisture of the adhesive
Lucky I decided to start again as it looks like tiles would have fallen of by the weekend.
I have no idea what I've done wrong, maybe too much adhesive? Or maybe its the Aquadefense, as i covered joints with the same (Mapgrip D2 Ready Mix) adhseive prior, and adhesive dried fine.
Any ideas?
Not a case of 'best' tubbed addy to use here. Due to the nature of the product it will take an age to dry if used over tanking. Why not use a standard set bagged adhesive. Tub life of 2 hours type thing? Will mean a bit of mixing but I honestly wouldn't advise a tub to use in this situation.
No, if it’s a wet area you need tanking. Change adhesive to bagged, not ready mixed.
" Do not use on metal surfaces and to lay nonabsorbent tiles onto non-absorbent substrates" wish I saw that on the tub.
Anywho, was on the phone to Mapei they told me to use KERAFLEX MAXI S1. Thanks guys.
In my (limited compared to some on here)experience, I found Ardex p9 to be an excellent alternative to tubbed adhesive, easy mix and an 8 hour pot life, after about 10 mins stuck, you will struggle to get any tiles off!
theandroids,
Slippery,
theandroids,
Slippery,
