Hi,
I was hoping I might get some advice with a cracked tiling issue I am experiencing.
We had a new bathroom installed about a year ago, and noticed the other day that half the top two rows of tiles along an interior brick wall are cracked.
We had a closer look around the bathroom, and found that there are also odd tiles cracked all over the bathroom. Some cracked right across, some with just barely visible hairline cracks a few inches long, a couple are blown out, as if hit from behind.
We are somewhat stumped as to the cause of this.
3 of the 4 walls have cracked tiles. All walls are solid brick.
The ceiling was plasterboarded over and skimmed before the tiling was done.
There are Silicon joins in the corners around the bath/shower, but all other corners and joins to ceiling are grouted to the corners.
The tiles are 500mmx250mm from Tile Giant.
We contacted the plumber who oversaw the job, and he is as stumped as we are at the moment. He is going to talk to the tiler, and in the meantime is going try to find out if there have been reported issues with the tile type/batch, and contact the adhesive manufacturer to check for issues and possible reactions (?).
Although I trust he will get to the bottom of the issue, we are a little concerned and hoped to get some 3rd party independent advice from some of you as to what might be the cause.
The only thoughts I have are:
It could be a bad batch of adhesive, or expired adhesive (if that is a thing?).
Possibly some kind of expansion that did not have adequate gaps left?
A mistake made by the tiler?
Some, but not all, of the tiles sound hollow when tapped as if there is a gap or air pocket behind them. Could air pockets left between tiles and adhesive expand with enough pressure to crack tiles?
My final thought is that I have noticed that the tiles that are cracked are all on areas of the walls that were painted, not tiled when the previous bathroom was in. (The tiles only went halfway up the wall and the top half was painted. The paint was typical water resistant, wipable bathroom paint, and was done by previous owner, who generally did not prepare well before painting and so the layer itself may not have been particularly sound itself). Is it possible that if the paint was not removed/prepared/keyed/bonded/stabilised first that it could be coming loose and cause cracking? It would make perfect sense to me if they were falling off, but could this actually cause cracking? If this were the case, should the tiler have not dealt with the paint before tiling, rather than tiling over it?
Again, this is just an observation and could be just a coincidence.
Any thought on this issue would be gratefully appreciated.
Thanks in advance
James
Take your issue back to Tile Giant who supplied the tiles.
This is not solely an issue with your job you should look into seeing if there is a group action against BCT for poor quality products.
Most likely nothing you can do now they have gone bust unless you are able to stake a claim through the administrators and then see if you can take action against Tile Giant for selling inferior materials. All long shots but IMHO it’s nothing to do with the tiler - he’s done his best - but poor quality biscuit/ glaze has caused this shrinkage as the adhesive has dried.
OK, so if it were shrinkage in the tiles, that may explain the cracks, but would that also create the hollow air pockets that seem to be evident that jcrtiling mentioned was likely to be due to bonding issues caused by paint, or spot fixing. Would it cause them to actually blow out?
Don't wish to play devils advocate here but Tile gaint might play the tiles have crazed for which they may try to say they don't gauantee against tiles going crazed, put the job been done over 12 months ago also ,sorry to put the mockers on it but you may find this is what they may try and say
My understanding is that crazing is cracking on the glaze, and not through the whole tile? Is this correct? Would be hard to claim its crazing if the tiles are cracked right through and blown out.
James from seeing the pictures you posted it looks like crazing ,but like I said you may be best to get the TTA out to inspect it because the report they give by all accounts is taken in to consideration should you have go down the legal route
SO many possible things contributing here.
Ultimate cause of the crazing though is weak tiles and strong adhesive.
As the adhesive cures, it pulls and pushes on the tile structure so you will have compressive and tensional stress across and through the tile.
Many of us here have experienced just how totally rubbish BCT tiles are, to the point we refused to fit them.
Spot fixing, tiling to paint, bed depth - all possible contributing factors, but I am 99.999% positive it's simply the tiles being weak with too great an adhesive bed / spots.
I'm pretty sure it's not crazing. Again, the tiles are cracked right through the tile, not just the glaze, and no longer entirely flat against the wall.
At the moment, I'm hoping to find some sort of reasonable answer without having to resort to TTA, as I would like it to be as painless and amicable as possible. TTA inspection would be too expensive to do unless we had no choice, and were forced to go down a legal route as a last resort. Cross fingers it doesn't come to that 🙁
Part of me feels that if anyone comes out to inspect anything then the installation better be flawless. I’m talking about correct substrate preparation and that adhesive bed needs to be as close to 100% as possible. No tiles on paint full stop and the weight limit of a plastered wall adhered to.
Otherwise I can see people wriggling out of any claim despite the material fitted potentially being at fault.
I would try to have a chat with your fitter and see what he can come up with. Who actually supplied the tiles? Was it supplied by the Bathroom company or you yourself?
sorry James seen the tile size 500 x 250 , in my experience I've never used expansion joints in anything under 5 metres long .but British standards quote between 8 to 10 metres,so the fact that no expansion joint may have not been used will not come in to it sorry
You have to have a soft joint in the corner bs states this
