Discuss Tiling a bath panel ??? in the Australia Tiling Forum area at TilersForums.com.
macten
1,158
Nottingham
hi guys I’m going to tile my bath panel well I’d like to but not sure how to go about it i was thinking of using tile backer board but the bath is a 1600 and I can only find boards that come in 1200 lengths.......how would you guys approach this ???
Get 2.
R
Ruel Miah
Ive always used 9/12/18 ml plyboard.
Does the job. But would depend on how much slack you have to get a finish
No need for fancy fittings in my view.
I just finish this job with 5.5ml ply. Screwed 3 baton Boxes behind to make more rigid.
Turned out as in pic
Waluigi
instead of the acrylic panels I specify wooden panels. Well it’s MDF with an acrylic coating. Usually consists of a top large panel and a set back plinth. The plinth rides up behind the top panel which not only takes up any irregularities in the floor level but also means that the bath height in relation to the final floor finish is far less important.
These panels shouldn’t be confused with the vinyl wrapped panels which are of an inferior quality.
LEH
108
Oxford
Funny how much argument tiled bath panels cause. I remember going through all the discussions when I was planning my (DIY) bathroom some time ago. I think they look nice and higher end than most of the (cheaper, at least) alternatives.
The most important thing that hasn't been mentioned so far is - you want to make sure your bath trap is accessible in the future! So you need to incorporate an access panel. Schluter have a good solution for this called REMA - magnetic brackets that mean the panel is virtually invisible.
So I don't really see the point for these ready made bath panel kits. Just frame out and board so that your panel corresponds to the grout joints either side of where the bath trap is.
Reply to Tiling a bath panel ??? in the Australia Tiling Forum area at TilersForums.com
Hey guys, I'm going to tile the patio and need my new porcelain tiles (10mm) to meet up with...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
First time tiling, lots of mistakes, but most of them have been resolved in a timely fashion so...
P
Hiya I know this was 10 years ago hoping you still use the same email address and get this...
Manchester
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 2 1.2%
    Votes: 5 3.1%
