Personally when I tile a floor I do all the cuts as I go. Some tilers seem to lay all the full tiles then do the cuts, can't see the advantage in this, got to be easier as you go like spreading addy up to skirting and cutting in am I wrong.
Discuss Tiling a Floor in the UK Tiling Forum area at TilersForums.com.
as above, depends on what tiles you using. If it's bigger then 300x300 tiles, you do full tiles first, then you can do only cuts, so mark and cut 10 or more tiles ( so it saves time, as you walk to tile cutter only ones)Personally when I tile a floor I do all the cuts as I go. Some tilers seem to lay all the full tiles then do the cuts, can't see the advantage in this, got to be easier as you go like spreading addy up to skirting and cutting in am I wrong.
Reply to Tiling a Floor in the UK Tiling Forum area at TilersForums.com
