Discuss Tiling a kitchen next week, Advice needed in the British & UK Tiling Forum area at TilersForums.com.
tysfoot
Hi, im tilling a kitchen next week but the only thing is that the old adhesicve is still on the wall but it looks like if i remove the old adhesive it will take chunks out of the wall, its plastered underneath.
if the tiles were big enough i think i could get away with just tiling over it but as there only small i can see the tiles wont go on straight.
I was thinking about sanding it all down with an electric sander
Another thing is that i have vastly undercharged which is annoying but if i do a good job i can do his bathroom the week after
Any advice on this would be very helpfull for me
DHTiling
If you are scraping and the plaster falls off as well, then it must have been lose..most times you just take chunks out which will be over come with adhesive but if plaster etc falls off then it needs replacing anyway..if you see what i mean mate...good luck..post us some pics in the gallery when done....
http://www.tilersforums.com/tilegallery/
GazLC81
Sanding will make a big mess and take you ages!
As Dave said try scaping it off while dry but if you are struggling the use of a steamer is very helpful. Just don't over do it! I have used mine a few times and it works spot on just don't leave it on an area too long.
I also sometimes resort to a hammer on the back of my spare scraper for the really tough bits that won't come off. If you don't fancy trying a steamer. Again don't get carried away.
Gaz
tysfoot
Cheers good advise lads so if i wont come off with a normal scraper all i have to do is give it a little steam then try scraping it off again.
What is the rapid se like, does it go on with a trowel like adhesive, how ong does it take to dry
Cant believe ive only charged 180 notes for ten metres of wall and floors of this kitchen, and it good stuff porcelin floor tiles.
Ive quoted so ill have to do it. Im new to tiling so its all learning for me anyway
Cheers for advise anyway
Reply to Tiling a kitchen next week, Advice needed in the British & UK Tiling Forum area at TilersForums.com
Hi all am changing tiles in my kitchen ans expect to damage the walls removing tiles . Think the...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
