Discuss Tiling Advice Wanted - Over Wet UFH in the Australia Tiling Forum area at TilersForums.com.
swampie
Hi All,
I have some 600x600mm Marble tiles to lay over an underfloor heating system and would like advice on adhesives and fitting please?
Floor Construction
  • [*=2]220mm Suspended timber floor joists - ***New build and pretty level***
    [*=2]Batons supporting 100mm Rigid Insulation Board between joists (set 25mm below joist top)
    [*=2]16mm UFH Pipe clipped to insulation Boards
    [*=2]Dry Biscuit Mix Screed, around pipework & leveled to joist top
    [*=2]22mm Moisture Resistant Chipboard
    [*=2]9mm Ply Screwed every 150mm
    [*=2]Kitchen Floor
So, what is the best method of fixing tiles to the ply to avoid cracking and lifting, I understand a flexible adhesive is needed but after reading some manufacturers fitting instructions, some are only good for tiles up to 100mm, some are super-flex but don't mention UFH applications. It's becoming a minefield of over-information.
Please help, this job means a lot to me.​
swampie
Thanks for the tips guys, I wish I had researched more earlier David but I'm now where I am unfortunately but at least I haven't laid them yet.
Yes that structured floor looks just the ticket, wish I'd got that down.
Ray, those are well worthy of further research, thanks for the tips. I'm not sure it'd beat the real thing though, these 600x600's are nice and will last "if laid correct". I'm scared of marking Vinyl.
So if I do tile, is keeping the ply better than removing it, when considering the advice of adding hardie backer and Ditra?
Is ply so bad? My joiner insists its the way to go. For future reference, never ply even without UFH?
ps My tiles are 600x600x15mm. Will the height make any difference to your opinions?
swampie
31mm of heat resistant wood
my advice bin the marble tiles the product I would lay would be karndean or amtico
Just spoke to a friend who lays vinyl floor and he also says the Karndean and Amtico have been known to fail as the heat melts the glue on occasions so I've a risk either way.
swampie
Why a biscuit screed?? it will hardly get warm with all that stuff on top...
Considering my floor construction and not wanting to raise the floor level, I wanted to install the UFH between the joists.
The decision to use this mix was made after several UFH suppliers confirmed that this system was the best U-Value compared to the metal trays which are already routed out for pipework and was the only other offered by my supplier without raising floor levels.
UFH companies don't really push this system as they'd rather you bought the products but trust me it works so far & I'm sure the tiles will warm. The system so far has been on for months now. It is nice and warm underfoot.
I have already finished the bathroom and in fairness, the tiles are not warm to touch before the room is up to temp, but that is a small room and heats easily. My kitchen may well require a higher heat.
See the design here
Reply to Tiling Advice Wanted - Over Wet UFH in the Australia Tiling Forum area at TilersForums.com
Hi everyone, With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a...
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
