Discuss tiling against a qudarant shower tray in the British & UK Tiling Forum area at TilersForums.com.
E
El Kabong!
All I need is a flat surface to put the mosaic up against. The weight is negligible. It is only 2 mosaic pieces high. One mosaic square against the foam and one against the tray face, still on their netting/backing, and grouted.
Less of the smart comments please. What should I do instead, fill it with floor adhesive and try to keep it flat? At least with the foam I can pare it back perfectly flat.
John Benton
1,138
Leeds
it's a slimline... probably about 10cm high
edit... gap is exactly 2cm, and tray is 5cm slimline
You can get the uPVC in different widths so you should be able to fix it with glue and then silicon without having to support it at the back
Reply to tiling against a qudarant shower tray in the British & UK Tiling Forum area at TilersForums.com
Hey. I doing my first walk-in tiled shower. The shower is 4’x8’. Most of the floor is covered...
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
  • Sticky
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
