Discuss Tiling an Attic conversion in the Canada Tile Advice area at TilersForums.com.
We want to tile the entire attic conversion with a 600 by 600 8mm Porcelain 8mm tile. The Attic is on 6 inch rafters and the largest floor is 4370 by 4775. Some tilers I've talked to have expressed doubts about tiling an attic like this, they say it will be impossible to do without continual problems due to movement, even with backing boards. Does anybody have any advice or any similar experience?
How far apart are the rafters? And is there deflection (bounce) in the floor already?
Can you not add proper joists to the supporting walls below? Is the floor covered already or something?
Hi Dan,
The joists are 400 apart and the floor is already covered in Chipboard. I'm just worried about movement after. When you ask about adding proper joists, what do you mean?
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Well, can you not pull up the chipboard and stick 12" joists onto the load bearing walls below? Next to the existing joists?
Effectively making a new solid suspended floor throughout. Is their enough height to do that?
I'm not a tiler by the way so wait for somebody who's done this before to reply.
But that floor doesn't sound solid enough.
Have you called Mapei Adhesive technical help line to see what they recommend in your situation?
Have you got a floorplan you can upload to the forum? How many rooms are there to take into account?
Thanks for the clarification Dan. It is something I could check, I think there is enough Height to allow it. I've attached the floor plan of the whole space. I'll try the technical helpline you suggested, thanks!
  • Attic floor plan landscape.pdf
Dumbo
Have you had an architect involved in this.
It may pay to spend a few quid and get a structural engineer to survey it and follow his recommendations on joist build up and loadings ,obviously telling him you intend to tile, not for his tiling recomedations but so he knows what extra weight you are putting in
Reply to Tiling an Attic conversion in the Canada Tile Advice area at TilersForums.com
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
Dear TilersForum Thank you so much for the outstanding advice and expert information over time...
Hello all. We have employed a tiler to do our bathroom and floor tiles. We bought the tiles...
5K
Hi all, I’m hoping someone can help. in June 18 we had some tiles fitted to the kitchen and...
8K
I'm a chippy, I fit a lot of kitchens and some bathrooms, inevitably I have done quite a bit of...
20K
Longford
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
