Tiling anything nice in September.
working on some high spec houses atm nothing but wet rooms in them. Tanking tiling the lot love it lol hope its all good for you lot on here too! 😉
This lot , 275m2 of modular on ground floor and level 2, and the 4 bathrooms adding to around 400m2 in total ! ;-)
looks like a bussy month again priced up 5 jobs in the last couple of days. got 3 emails to confirm go aheads.
one is 2 bathrooms fully tiled and the whole house 3bedrooms living room hall and kitchen dining room all to do in karndean vinyl
the 2bathroom in jura limestone
it pays to diversify lol🙂
I've just done a hallway over the weekend in 600x600x20mm porcelain.
On going project with a bit of this......
Bit of that......
Got a large area of travertine starting toward the end of the month too
What you gonna use on external asphalt? I did one years ago and nobody would commit to a spec.
Well Paul @AD Ceramics spoke with Glynn from Tilemaster this morning and following a very interesting and informative conversation, this is the outcome.
Firstly there are 4 grades of asphalt! (Who knew? Haha not me that's apparent!)
So providing it's grade A or 1 flooring asphalt, (however it's classified)
My original method was correct, apart from replacing the primeplus slurry with their new Primeplus Grip!
With one addition, because there will be exposed edges around some of the tiles, won't bore u! The use of Ardex WPJ or Mapei Adesilex PG4 to seal any exposed edges from moisture ingress! (Makes sense)
This method has also been approved by Tilemasters Chemist, just this morning!
So a big thanks to @Glynn for such a precise solution to the problem and for even suggesting the use of other manufacturers products (which he named) to give a complete solution to the problem! *tips hat!*
And thank you Paul, @Dave & @Plan Tec Tiling 😉
That's good Marc, I knew there was different grades and understood the standard flooring grade was ok to tile on, the one I was doing on the balcony in question was very oily/greasy and that's the only reason I question the procedure.
Have they arises you which grade you are tiling on? Or is that what you are saying its flooring grade.
We learn every day thanks for info.
No no thank u! Haha
I'm still waiting for architect to confirm grade.
But at least my end is sorted!
There's a little part of me hopes that the asphalt isn't up to standard! Haha
Don't fancy leaping across roof tops, I'm not bloody Dick Van Dyke! Haha
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
