Discuss Tiling around door frame in the Canada Tile Advice area at TilersForums.com.
Boggs
1,118
Uk
I would take down the jackoboard on the stud work and refit but sticking it with some rapidset.
Screw back through your studwork and fix again using some spring toggle fixings midway between the studs leaving you with a 200mm centre fixing.
Best be safe than sorry especially with that size/weight tile.
James De
You’re totally right. Can’t say I’m not gutted as I’ve tanked the wet area now. But I like sleeping at night so I’ll do what you’ve suggested and just retank the joins when I’m done. So stressed I need to finish this job by Sunday.
Boggs
1,118
Uk
If it’s already tanked why not just reduce the spacing with spring toggle fixings.
Combined with the washers this will give you a really good strong fixing to the background.
Boggs
1,118
Uk
No point rushing it, the only thing to be learnt by rushing is to cut corners and make mistakes.
Boggs
1,118
Uk
Just make sure the walls are spot on, you need 100% coverage on those tiles in the wet area.
I’ve not fixed tiles that size before and I would be double checking everything before I even took one from the box.
Don’t rush the tanking stage either that needs to be spot on otherwise that’s going to cost big time!
Progress pics too please :D
Reply to Tiling around door frame in the Canada Tile Advice area at TilersForums.com
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
WHOLE BATHROOM REFIT - ALL WALL FULL HEIGHT TILING AND TILED WINDOW LEDGES. ONE SMALL WINDOW &...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
