Discuss Tiling around door frame in the Canada Tile Advice area at TilersForums.com.
Waluigi
You tank over the washers.
Screw wise, you have a 600mm Board with two fixing points at either end of the 600mm with no adhesive behind the board. Not very secure IMHO, especially with 6mm board.
Maybe it’s just me. I don’t do many overboarding jobs. I think the last time I did a wall I used HB, 6mm. Glued and screwed.
acaciaguy
568
Warwickshire
Copied from another thread about Jackoboard
JACKOBOARD® Plano construction boards can be fixed to timber or metal stud frames using JACKOBOARD® 36mm diameter galvanised steel washers and appropriate screws. If the frame centres are 600mm apart then boards of at least 20mm thick should be used. Fastening points must be arranged as per figure 3 or 4. If the frames are at 300mm centres then 10 or 12,5mm thick boards can be used. Fastening points must be arranged as per figure 5 or 6.
As the boards are over plasterboard in this case I don’t know if the same recommendations apply
acaciaguy
568
Warwickshire
Do you tend to rip out plasterboard and replace with hb etc
Boggs
1,118
Uk
Was 400mm centres between studs
What was the background surface?
You mentioned bonding in a previous thread was this over skimmed?
Waluigi
where the boards join, you can get away with a fixing staggering both boards.
The issue you have if you don’t glue the boards is that any inperfections in the wall, dips or bows, aren’t accommodated and you essentially could have a piece of 6mm board floating. More screws are essential, to pull the board tight to the wall if nothing else.
James De
Is it a mixed wall substrate room? Skimmed bonding ? Plasterboard on studs?
Only one wall was mixed: one side was bonded over block, so drilled, plugged and screwed the backer boards over the bonding using 4” screws to get 3” of the screw into the block, the rest was plasterboard stud walls with a skim, so screwed the boards to the studs
Reply to Tiling around door frame in the Canada Tile Advice area at TilersForums.com
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
WHOLE BATHROOM REFIT - ALL WALL FULL HEIGHT TILING AND TILED WINDOW LEDGES. ONE SMALL WINDOW &...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
