Discuss Tiling around door frame in the Canada Tile Advice area at TilersForums.com.
James De
Just make sure the walls are spot on, you need 100% coverage on those tiles in the wet area.
I’ve not fixed tiles that size before and I would be double checking everything before I even took one from the box.
Don’t rush the tanking stage either that needs to be spot on otherwise that’s going to cost big time!
Progress pics too please :D
Yeah I’m a bit anal when it comes to tanking.. mainly because I deal with leaks all the time in bathrooms so I like to make sure my work is leak free..
Lol I’ll post pics as I go.. unless I really balls it up :confused: haha
James De
When trowling the other boards, you think a 6mm is too small? Would you go with 8mm?
James De
Last bit of tanking done after putting in another 30 toggle screws that can take 50kg each on a downward pull!! Next: scrape and clean the tray, membrane installation and then setting out ready for slapping on those bad boys! Been here since 7am
James De
Last night I nearly mentioned about spring toggles having a bolt instead of a screw which means the screws aren’t countersunk into the washer. I see you’ve found that out.
Haha yes.. it sticks out by about 3-4mm which should fit within the adhesive as I’m using a 10mm trowel for those big tiles and back buttering the tiles as well. Unless you think I need to do something different? Bas**** builders stacked 3 plasterboards on top of each other so had to go get longer m6 screws to fit the toggles on the wall the shower is on :mad:
Reply to Tiling around door frame in the Canada Tile Advice area at TilersForums.com
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
WHOLE BATHROOM REFIT - ALL WALL FULL HEIGHT TILING AND TILED WINDOW LEDGES. ONE SMALL WINDOW &...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
