Discuss Tiling around pipes in the British & UK Tiling Forum area at TilersForums.com.
Jeffrey4670
Hi, I have problems with 15mm copper feeds to towel rails in bathrooms. I never cut around pipes and always use hole cutters " 19mm" with chrome pipe covers. As I am a plumber, I have the added advantage of diverting the feeds under the floor to emerge under the bath and fit gate valves. Then go back to the position of the towel rail, which means I can have the towel rail feeds up though the floor to drill around. Then fit towel rail and turn on. Regfards Jeff
The_Master
can be a big mistake finishing off someone else's work i.e how do you know they have set out properly,you could be left with crap cuts at sinks,baths windows etc,so a bit of advice THINK TWICE.
I dont mean to sound harsh but get yourself some training before taking on projects like this,you have been warned.:wink_smile:
i just felt i needed to make a POINT here!!! yes we all hate finishing off someones elses work, id rather not ie you dont know if its level,plumb decent cuts at top and bottom of wall, floor etc, BUT if i go into a bathroom and the job requires me to only go round the bath, i do not take the rest of the bathroom into consideration if its not getting tiled, i only concentrate on the job at hand, not my fault if the customer decides to tile rest of the bathroom 1 month later, and the tiles dont fall exactely into place, if its a full bathroom then i take everything into consideration if its about a bath then i only take that into consideration, look daft only tiling round bath and having stupid cut up the edge of the bath cause it doesnt work out with rest of wall that isnt gettin tiled, so think twice before slagging off other tilers settin out!!!!!!!!
The_Master
Hello, it may sound a bit of a daft question but when you have to snap a ceramic tile across hole centres to fix it over pipes do you have to glue it together as it is fixed on the wall? If so I'm thinking superglue as anything else will be too thick and open the cut. I'm asking as someone at work has got wind of me wanting to take up tiling and wants me to finish their bathroom. The tiling I'm going to do is a continuation of the tiling around the bath so I can't set the tiles so the pipes are at the edge of a tile. As luck would have it two water pipes exit the wall nearly bang in centre of a 20 x 30cm. tile in full view. Thanks a lot!
sorry m8 went on a ramble there, use a hole cutter if seen or split the tile if not seen then just stick it on the wall, dont put any adhesive between the split as this can make the split more prominent , if you split the tile right u can push the two halves together and hardly make out the split as they are from the 1 tile ie fits like a glove
Deleted member 1779
Absolutly do not break the tile. Drill it. We supply a decent set of drills that will whizz through ceramic.
GO to our website. Select option 4 (on the blue nav bar) and then review topic Drilling soft ceramic tiles.
All you need is there...
The_Master
i agree every time 365 HOLECUTTERS but not always possible when Pan And Sink are connected, didnt point that out in my previous post must have been still on the ramble
Simon.
Thanks The Master. I've done the tiling for a work coleague and split the tile and all looks O.K. I had no choice as the pipes for the sink came up through the floor, went in to the wall above the skirting board and exited the wall again just below the sink and was told not to touch it. Was quite a bit of hassle as the tiles were thick and the pipes went into the wall at a shallow angle. Good experience though. Last time I do tiling after working a ten hour night shift.
Reply to Tiling around pipes in the British & UK Tiling Forum area at TilersForums.com
Tiling around pipes
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
