I
imperato
yer it deffo has 2 pipes going into the right side, ive seen this done before so i should be fine. just wonted to no if i had to turn the hole suply of water of or if its fine to just turn off the valve
hiya guys just a quick question, im starting a job monday and i have to remove a radiator to tile behind.
some people might find this a silly question but i havent had to remove 1 before. when removing the radiator do i have to cut all hot and cold of in the house ? or do i just turn the valve off on the side of the radiator?
Two pipes into one valve Rob
this won't be a trv Mike but some do only go to a frost setting. In these cases unscrew the top of the trv off, put a 5p piece inside and screw back on and screw down. this usually shuts the valve offim my experiance tsv's never turn off fully and must always be capped or the system drained
