Discuss tiling external steps in the British & UK Tiling Forum area at TilersForums.com.
jonty
thanks for the replies, Grumpy i hope my steps look as good as yours when i'm finished i'm going for Ruabon tiles too collecting tomorrow but could you help me out with a few questions.
Do i need to allow for an expansion joint on the top step row of tiles or do i need to put an expansion joint in every step? how many mm do you leave? can i put any Silicon sealant in the expansion joint or does it need to be external? and what size of spacers did you use?
With these tiles i think i need a sealer is it correct to say i put the sealer on before grouting? thanks
grumpygrouter
Thats the first time I have seent that pic Russ, is that the one where I scribbled a mad plan for you to follow ? worked a treat nice job mate....Gaz
Thats the one Gaz. Glad you like it.
Jonty, assuming that your steps are concrete and it is a small area the expansion on the steps would not be that great to require a movement joint. I didn't have one. Just make sure you use a flexy adhesive and grout.
Ruabon tiles do not require sealing. If you register on the ruabon website , there are a number of useful helpsheets available. It states very clearly that they should not require sealing.
I used 5 mil. spacers but in all honesty the Ruabon tiles are not that consistant in size so use that as a guide only and adjust using eyeball as necessary - Ruabon suggest a minimum of 6mm.
Grumpy
Reply to tiling external steps in the British & UK Tiling Forum area at TilersForums.com
    • Friendly
Hi, I’d appreciate some help with lay out for four walls with following measurements. I want to...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
