Discuss Tiling my house, need some advice in the British & UK Tiling Forum area at TilersForums.com.
tek_01
Hi all, new to the forum so take it easy on me :lol:
Basically im up to the tiling part of my house and what i have done so far is on the 65 sq m of floorboards have secured them all down with screws into the joists and packed any gaps under the house between joists/bearers/piers.
I Have then nailed down some ceramic tile underlay (compressed fibro stuff) in accordance with manufacturers instructions leaving expansion joints at all door ways. So far so good...
Now i went out and bought 600x600 polished porcelain with square edges (no bevel:yikes:) because of the look and price was in my budget + the wife was nagging me she wanted them so boss wins. Now the floor is far from flat in some areas but it would cost me WAY too much to put down floor leveller so im going to have to try make do with bit thicker/thinner glue in some spots.
I have bought the LASH tile spacers in order to make my life that bit easier. Good choice for a newb? I understand these wont level my floor but will aids in having no lippage.
Also, i have a 100mm step down into my lounge room. What should i do on the edge there? I was originally going to put some caesarstone strip about 150mm along it (3m length) but am now thinking just to bring the tile right to the edge. Any thought? Dont really want to put an angle strip thing there as it would look crummy
Ive got plenty more questions but this will do for now
tek_01
Im from australia so unsure if you guys will know the brands but anyhow ill state what they are
Floor is 19mm hardwood t&g (prob 50 yrs old). The underlay is james hardie Ceramic tile underlay
The glue im using is going to be a 2 part flex, most expensive. Davco Tradeflex is the name. Also going to prime the fibro with Davco Ultraprime.
I Know there is going to be bounce but im past the point of tearing up floor boards (and over budget). Do you reall think i will have problems?
tek_01
Ok, How much bounce is acceptable? When walking on the floor i havent noticed any bounce but being wooden floors, im sure there is 'some' bounce. Any creaking while walking i have fixed by packing any gaps underneath the joists and also using 100mm batten screws thought joists and bearers.
I could (painstakingly as there is less than 60cm gap) go back under the house and put noggins in between joists but im not sure how this will fix 'up and down' movement? and nailing wont work into this hardwood as the gun shoots them only half way so pre-drilling and screwing is the only way i will get the noggins in.
So basically, how to measure bounce?
Cheers for the replies so far
tek_01
Sorry dont know how to edit posts so have to double post. But incase there was a misunderstanding, i have screwed down each floor board to every single joist (where the old nails where) so there are no loose floor boards sitting on joists in case thats where you are talking about bounce??
Im taking about the whole floor moving up/down... which can only be fixed (I think) by either more piers or thicker bearers/joists.
jay
You need to sort out the movement first noggins or wedges under stumps if required .the lash clips may help but they state that with lash clips the floor must be level before use see if you can exchange the clips for some self leveling compound .your adh is not one i would recomend and think you could do better there .how big is the floor
Reply to Tiling my house, need some advice in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
