Tiling my shower....
And the outcome was......
Not yet decided but stripping back to studs is not an option. too big a job and too costly. I'm thinking it will be tank existing, stick backer boards on with silicon and the mechanically fix them as well. Then tank secondary layer. Then get on with tiling. Still not decided for sure yet though. Got to finish the other bathroom first so I can decommission the shower and still have a wash....
Am I missing something?
Your problem isn't the wall or tiles, it's the deflection in your joists. Reboarding, tanking, re-tiling won't solve your problem because as soon as you walk in to that shower again the tray will move and break any seal you have just made.
Is this on a first floor? If so can you tackle the problem from below? I'm assuming so if you've noticed the leak.
Remove a section of plasterboard from below and shore up the joist by adding extra noggins, joist hangers, slate packers... whatever you have to do to lessen the defelection.
Get the other bathroom finished then get a dehumidifier in the shower and let it dry out, then just simply resilicon the shower as it is without retiling... unless of course the tiles are falling off the wall? Or maybe just remove and re-tile the bottom tiles? Not sure how bad this leak has been?
You are right... I forgot to mention in the last post I have beefed up the floor from underneath as well... Did that last weekend... Nightmare of a job as there are pipes and cables running up there and typically all in the wrong direction. That bits done. Not the tiles are not loose. Beleive it or not they are still solid which has surprised me because when I tiled it all last time I used tubbed gear.... But there you go. Got me backer board today so one step nearer.
Not sure why you're re-tiling it then mate? if you've taken the flex out of the tray then why not simply reseal?
How is the shower finished? i.e tiles out of the shower cubical. I'm wondering how you're going to deal with the transistion between old and new above the shower enclosure. You could use tile trim but that going to stick out like a sore thumb once you added 15-20mm of backerboard and tiles. If I walked in to a bathroom like that my eye would go to it instantly and start wondering what nasties are underneath... but then I suppose not all homebuyers are tradesmen.
Your spending to much time 'debating'with swedish knobjockey mike rob, you seem to be getting grumpy these days [emoji16]
Really, did that come over as grumpy😳 it wasn't ment to. Made me feel bad now!!
Thought I'd give Mike a try, mean to go back but just not got the time at the moment
Ha ha no not really rob , I'm kinda joking, I read the thread on the other forum, but I've never posted , I just can not be bothered .
