Anto is a wind up, his threads seem to be just fishing threads, he gotta to be a troll
Tut tut......bit unfriendly. ....thats whats wrong with this forum latley....:lol:
Discuss Tiling on Thistle Bonding in the Australia Tiling Forum area at TilersForums.com.
If you really really have to without having the surface finish coated, do what I've had to do for builders. Don't use PVA but a decent primer and then skim with the adhesive you are going to use. I've had to do this many times for skin flints and to be honest never had a problem.
I would however not do this for a wet room/shower. Kitchen splash back should be fine (ish)!
I think we have to look at this from a realistic point of view, would I tile to it?
Probably...
It's only a kitchen Splashback to be fair, if it fails then there's only one person to blame.
It's not right but sometimes you have to go against the grain...
Aye... Had to make a choice. Walk away or do it. Can't walk away as it was planned around other work...
I'll keep you all posted anyways. 2 tiles high on one wall which was treated very well before hand.
Wanted to plaster skim it but couldn't due to time
Cheers Stef
I'm not agreeing with you but sometimes you have to look at it in perspective & assess the situation.
If it fails is it going to hurt someone?
The answer is no so I would tile if I needed the work.
The only thing I would worry about is that if it does fail then you can get a bad name about yourself.
Do a job right the 1st time....
A mate (who's a brickie) who put hardboard down on his floorboards using tacks then tiled on top, it's been down 6 years and not a crack in sight....how?????:yikes:
Hello, Did you use the "green grit based" Thistle bond product or a similiar bonding product as some of the replies lean towards you having used basic bonding.
The Thistle bond i know is anything but "smooth" as it purpose is to offer a "key" to the job.
Anyway my dog is really old and I'm worried about him
Reply to Tiling on Thistle Bonding in the Australia Tiling Forum area at TilersForums.com
