Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Tiling on tiles-a bit over max weight in the Tiling Standards area at TilersForums.com.
MTiler
Hi
Im supposed to be doing a job next week where two of the walls (bathroom) are tiled and the customer doesnt want to take them off.
The existing tiles are bog standard thin ceramic tiles on plasterboard but the new tiles to be fixed are 400x400 x10 ceramic tiles.
After getting the customer to check their weight, as I was a bit concerned, it was found that a m2 of the tiles weighed 17kilos making them 1kilo over the 16kilos max weight for tile on tile.
Thats not including the weight of the adhesive (Instarmac - broken link removed )
Is even just 1 kilo over a definate no no, and tempting fate, or is it a guideline so people dont go mad?
The customer suggested contacting the adhesive company but even if its fine to hold onto the tiles that doesnt mean the existing tiles are going to hold surely.
cheers for your help
MissyT
DHTiling
Hi Missy t....
This is all down to the existing tiles....Can you be sure enough they will support the weight of the new ones..that's the main concern here..you can tile on tiles no probs but that format you are going to be using to me is just a big NO NO...
My advise is to start a fresh ...then you can guarantee it will be ok..otherwise it is just pot luck that the existing ones are solid.......let us know how it goes....
Dan
Admin
Staff member
5,086
1,323
Staffordshire, UK
I think the 16KG includes the adhesive - but is half of the 32kg the plasterboard can take total. Assuming your existing tiles are about 12kg, your new tiles could be 20kg (including adhesive) providing the adhesive can hold the 17kg tile.
If the adhesive wont hold, go to BAL ;) they'll have one that will.
Saltire69
Had the same problem Missy recently with a customer. Told them they had 3 options. Let me remove old tiles,Change tiles or get a new tiler to do the job. I didn't want to risk it. They had 2 young kids and i just explained the dangers involved if a tile was to fall off when there kids were in the bath. They changed the tiles eventually
Reply to Tiling on tiles-a bit over max weight in the Tiling Standards area at TilersForums.com
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
  • Sticky
I never tile over tiles. However, in this case I have a small area that is a shop front and I'm...
NZ_Tiler
N
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
Hi everyone I've done several trades across construction, and the thing I struggle most with is...
12K
Tiling Standards
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
