Discuss Tiling onto ply - another thread...... in the Canada Tile Advice area at TilersForums.com.
K
KateJ
Tiling onto Ply - OK - just seen the other thread and it's 'No you can't'.
Is there no product I can put down to firm up the surface to make it right for tiling?
Or shall I just give up????
I know there is flexible adhesive (or special 'onto wood' adhesive and grout).. is it still impossible?
My floor is 18mm ply and if I'm honest a tad springy here and there...
Kxx
L
LM
It doesn't matter what you do if the floor is springing this needs to be strengthened to eradicate all deflection.
Then you need to incorporate a decoupling layer like Ditra 25 or BAL rapid mat into the tiling.
Plywoods nowadays aren't what they used to be!
As someone on here states "Fail to prepare then prepare to fail".
L
LM
That really depends on the actual deflection, as PDC above says you need to lift the floor and install what ever support necessary to eliminate the deflection. If you don't address the deflection it's more than likely that the floor will fail in some form or another.
This is one corner you can't cut I'm afraid if you want a successful installation.
Reply to Tiling onto ply - another thread...... in the Canada Tile Advice area at TilersForums.com
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
