Discuss Tiling over 22mm T&G chipboard in the Canada Tile Advice area at TilersForums.com.
Mark1979
Hi,
I'm currently renovating and my next job is tiling. I have new T&G 22mm chipboard screwed down in the new living room extension on joists well above specification so it shouldn't move but it is chipboard so it might in time. I've now decided to install quartz tiles...
My understanding having taken a lot of advice is that I need to:
- prime the chipboard (with something like BAL Prime APD)
- Install hardi backer 6mm on a layer of 2 part flexible adhesive (no water) with 6mm trowel and screw down (taping edges per manufacturer instructions and staggering boards so joints don't meet)
- install tiles using a 2 part flexible adhesive (6mm trowel) per above
- use flexible grout (or epoxy grout)
I'd appreciate any comments you may have and also your suggestions for the 2 part flexible adhesive and grout/epoxy grout to use. Once it's done it'll be down 20 years so don't want to skimp or miss something and cause a later problem.
thanks in advance
Mark1979
Personally speaking I’d opt for Schluter Ditra 25 uncoupling membrane stuck down to the chipboard with Ardex AF200 and then lay the tiles with a minimum C2 adhesive.
What are the dimensions of the area, have you considered expansion joints?
Hi Lee Mack, thanks for your comment.
The topic of expansion joints did come up at the start and I think we got to not needing them but I cant remember the detail of the discussion. The area is approximately 7 meters by 6 meters and I think I was told that I'd only need them if it was 8 meters in any direction. Does that sound right to you?
Regards,
Mark
L
LM
Regards,
Mark
I don’t know how but I’ve just realised that it’s a Quartz tile you’re fitting, don’t know how I missed that in the title at first :eek: Do what @Local has suggested.
Mark1979
If you are installing Quartz then I would use Tile Master Ultimate as the adhesive.
I personally would fix tile backer board 10mm over the T&G floor. Fixed with adhesive and screws. Its easier to worth its that Hbacker.
Thats what I would do.
Hi McLovin,
I've heard a few people singing the praises of tile master ultimate. Is it a two part?
Reply to Tiling over 22mm T&G chipboard in the Canada Tile Advice area at TilersForums.com
Hi - I'm laying hardiebacker on top of green chipboard. I have a load of Mapei Primer G left...
Hi all, I'm an enthusiastic DIY'er (first time poster) who has been slowly chipping away at an...
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 2 1.2%
    Votes: 5 3.0%
