Tiling over Amtico - possible?
It's too complex for me as a DIY'er, but if you or anyone has recommendations of a good tradesman in the Didcot area let me know.
If the Amtico will not come up without a fight you can use an orbital sander with coarse grit pad to remove the pur coating ,then prime with mapei grit bond. I would then use a screed such as Ardex na at a minimum of 3mm then your good to go. Have done this a few times with no problems. A word of caution though if there is under floor heating the Amtico must be removed.
