Tiling pleasure beach fun house
So what is the problem? This is surely the normal standard of plastering in the UK. If each wall is flat (both ends of the wall and all points in-between lean into/out of the room by the same amount) then it can be tiled without a problem (other than matching joints at corners). It is when the left end of the wall leans into the room and the right side leans out then you have to bend the tiles.
No it is'nt, any plasterer leaving work like that should hanging up his trowels or himself....
Tiling window wall plumb is essential for top finish as bugs has advised. A for the other wall being off plumb by 3 inch well that's no problem, tilers can tile sloped ceilings easy lol.
wickers,
charlie1,
wickers,
charlie1,
