Scott the tiler
Could anyone advise me on tiling onboard a 7million euro yacht.
The spec is there are 15m2 of marble tiles 3-4mm thick already installed. Problem is the chair and table leg keeps going through the tile as the marble is so thin. The original installer siliconed the 4 corners and placed wood crossed under the tiles as there is a 10mm void underneath. As these have moved problems have just begun!
Problem 2: Weight is a very important issue as 15m2 of 4mm tile is approx 400KG
I need to obviously fill this void with something light but strong, also there is an UFH system laying loosely any ideas on the type of glue to use?
Thank you
Thank you
