Discuss Tiling round porthole window in the British & UK Tiling Forum area at TilersForums.com.
I
inspiredandy
Look at this attachment.
This is a job i did a couple of years ago and if i remember rightly the mosaic was set back from the edge about 3mm so you could get a good grout finish around the circumference of the porthole. Check the led lights in the step to the bath, wot a pain in the *** that was.
silver
I did an arch that way Dave with regular cuts on the trim flat at every 20mm...I did use a couple of small flat head tacks to hold it in place aswell.......first attempt I was " a bit clumsy" and curving it creased a white line in the soft cream where it bent instead of curving.....so that went in the bin.....but the second one I took my time and it worked a treat ...it took longer to file the tiles to get a nice finish right up to the trim.......but it is worth it.
Silver
DHTiling
Some one mentioned schluter stuff as well.....
Uniform Bending Of Profiles With Radius Perforations
Certain Schlüter profiles with radius perforations are available for the protection of contoured edges. The perforations make it possible to adjust the profile to the contour of the covering edge. To achieve quick and neat bending of most profiles with radius perforations, use the specially designed Schlüter-RUMA bending machine. For full details of profiles with radius perforations, and which are suitable for use with Schlüter-RUMA, ring Schlüter-Systems Ltd on +44 (0) 1530 813396. The picture shows an example of how a Schlüter profile can be easily contoured to fit a neighbouring curved surface. Products that are only 1 metre in lengh are not availabe with radius perforations.
tile55
Here's one without trim...............Looks the DUCK's Dangles me thinks
Blimey a bit too much on the old amber nectar there, I thought that it was the 'dogs dangly bits' Australians ay lol:gettree:
Picture looks excellent, as asked before, are those tiles oaround the edge precut, ie like quadrant tiles.
Reply to Tiling round porthole window in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
