Tiling slopes
darrenba
Can any of you guys suggest the easiest way to tile the underside of these stairs (see pic). Tiles will be 12x10 ceramic. Will they hold in place or do I need to support them somejhow? Any suggestion on adhesive to use?
Obviously the artex and light will be removed beforehand.
Never done that type of job but I am pretty sure that any good adhesive will hold that size of ceramic OK. is the surface to be tiled plasterboard?
Grumpy
Funny tiling. Go ahead like this:
- Prime the boards to prevent moisture reching the gypsum plaster.
- Take an adhesive C2FT or C2FTE acc. to EN 12004. The (T) tixotrophic component and the (F) fast hardening will help to keep the tiles in place.
- Buttering-floating should be done for good tile´s backside covering and helps to withstand the earth´s gravity force which is trying "to suck" the tiles.
Cheers from Germany, Martin
Onto plasterboard like that I would only recommend mosaics, fixed with mosaic fix from bal.........Gaz
Use backer board and flexi cement based adhesive and flexi grout....make sure you get a solid fix.....it needs to be solid to take any movment from the stairs.....
thats a weird one,never been asked to tile a roof before,just watch that the tiles are not too heavy incase the fall,dont think i would do that job im afraid.
Tiling slopes
Tags Tags
tiling usa
darrenba,
Leatherface,
darrenba,
Leatherface,
