CraigH
Hi Guys,
New here so hope this is in the right place. I am about to start ripping out my En suite. Now im not a tiler but am fairly compotent and have done tiling before, although on a smaller scale.
By shower is currently on a raised tray with 3 stud walls surrounding it. the space between the tiles across the tray measures 720mm.
I am assuming at this point that as trays seem to eb either 700 or 760, that it is a 760mm tray that is sat under the wall. (The tiles sit on top of the tray so it goes under these at least).
Anyway, the plan is to take the room right down to the stud and re board the walls. So am i right in saying the following.
1. Fit a 760mm square tray.
2. Board the walls with them sat on top of the tray (Using Knauf Aqua board and leaving a small gap).
3. Fill the gaps with the Knauf Jointing adhesive and Knauf tape (As per the Knauf website)
4. Tile direct to the boards.
Is this correct? I am aware of the people saying these boards should still be tanked, some saying they dont etc so am a little confused.
Also whats the best adhesive/grout that is up to the job? Have always used Al Murads own brands to be honest but never tiled a shower cubicle before, just odd walls here and there that dont get wet (just steam/condensation).
