Discuss Tiling without batten in the Canada Tile Advice area at TilersForums.com.
Just cut your bottom row in after setting out and away you go
Sorry to be a pain, but would you mind giving a step by step on that,Just cut your bottom row in after setting out and away you go
Ok well the only issue is that i have a shower tray installed, so as long as this is level, could i get a straight line right roubd the room from this? As long as the vertical/horizontal cuts work with setting out, and work down from this line to the floor??? Wud this work, down quite underatand how to cut in first row tiles, what height etc??Evening James. I have moved this thread from the Welcome forum into the Tiling Forum.
Please do post again in the Welcome forum and introduce yourself and abilities a bit more.
Cutting bottom row in after setting out basically describes finding out what your layout will be, then tile first tow of wall tiles from floor, but measuring and cutting so the tops of all of the tiles are 100% level with each other. This then allows you to tile from this level thus eliminating the need for battens.
I would like a nice full tile to run round the bottom of the shower tray as long as level, and for that level ti run right round all the other walls as long as it works, but i dont want to use a batten , and just wondered how i could get down to the floor then work up, would a good grip adhesive help? There only 4x12 tiles, not heavy,That height of first row is your choice depending on the planned layout and obstacles in the room. From what you are describing it sounds like you are wanting to lay a full tile first. Am I correct?
No not my 1st tiling venture , i am confident in my tiling, but is my side job, and has been a little since i did a big tiling job, both shower walls tiled wall to ceiling and the other 2 just half way up.. and rile the floor. well im certainly hoping they fit the shower tray level, ok a good grip adhesive sounds good..That's the issue..... you are hoping everything including the floor and tray are bang on level which they most probably won't be. Work out a few different layouts and see what works best as the first tile. More often than not a half to 3/4 tile works best.
Just use a polymer modified cement adhesive with good initial grab.
Is this your first tiling venture?
Batten is much easier, removes a lot of potential heartache. If going without, find lowest point in floor, set your first tile, mark wall around levelling from this, measure and cut from this line, checking frequently for level and alignment.
Reply to Tiling without batten in the Canada Tile Advice area at TilersForums.com
