Discuss Tiling without batten in the Canada Tile Advice area at TilersForums.com.
Hi James,
To be honest mate, however you want you tiles to fall I don’t understand why you’re so adverse to using batons.
I have a laser level and a good selection of 3”x 2” CLS in various lengths. It takes me about 15mins to baton out a bathroom and at the end of it you have the security and peace of mind that everything is in the right place and there’s gonna be no slippage.
My advice would be to stick with the batons and play it Safe mate. Cheers Dave
H
Handyeire
Batten is much easier, removes a lot of potential heartache. If going without, find lowest point in floor, set your first tile, mark wall around levelling from this, measure and cut from this line, checking frequently for level and alignment.
agree! Make sure its a plained batten thou
df1777
Why does he need a batten with only 4x12 tiles? They won't slip and I'd be using ready mixed. Draw a line with a level half way up the wall if you want, spread it and off you go, just make sure you ain't got any small cuts. I should have a PhD
.... throw the batten out the window, watch the next door neighbours cat though
Reply to Tiling without batten in the Canada Tile Advice area at TilersForums.com
Hey guys, I'm going to tile the patio and need my new porcelain tiles (10mm) to meet up with...
Hi, I’d appreciate some help with lay out for four walls with following measurements. I want to...
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
Im changing a bath to a tray for a friend and the bath was chased into the wall on all 3 sides...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
