Discuss tiling wood floor to concrete in the British & UK Tiling Forum area at TilersForums.com.
Mike
Hi all, i've got a kitchen floor to tile (solid floor boards) but a small section (about 6 foot by 3) has been concreted. i'm screwing 1/2 inch ply on the floor boards and bringing the concrete level with slc but what i need to know is what mesh do i need to put over the join between the 2 substrates? thanks in advance as i'll not be back for a few hours
Rich
Youl want to leave a movement joint between the two substrates of about 2-3mm. You can either appy the SLC then run a electric saw down the edge of the wood to make the joint or place something along the edge of the boards before you SLC (Id prod go with the first one of those). Leave this joint clear, dont fill it with anything. Then this movement joint needs to be followed through the tiles, so try and lay your tiles so that a joint falls over this movement joint. This joint will need to be filled with Silicon rather than grout.
Hope thats some help :thumbsup:
Mike
thanks for that richard but do i need to put a mesh over the joint (in the flexi addy to strengthen the transition joint?
Reply to tiling wood floor to concrete in the British & UK Tiling Forum area at TilersForums.com
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
