Discuss Took The Plunge. in the Australia Tiling Forum area at TilersForums.com.
Well if u've already bought it, the question is a little irrelevant, is it not!Yes mate, I did say in my first post!
I think you may need to read the first post again and slowly.Well if u've already bought it, the question is a little irrelevant, is it not!
Doesn't matter what I think!
U can come to your own conclusions.
I like them, u may not!
It's a subjective topic!
You can find DNA blades for Tile Cutters at a very reasonable price from TradeTiler.com
180mm to 350mm - Links below.
Montolit DNA Blades
DNA represents the most important innovation and a genuine technological revolution in the field of diamond tools, since the introduction of laser welding in 1980
The diamonds are precisely arranged in individual positions around the circumference of the wheel. Even the orientation of the diamond grains is controlled!
The result is a blade that effortlessly cuts with minimal chipping on a wide range of materials with amazing speed and durability
Suitable for:
Wet cut only
- Fantastic on porcelain!
- Quartzite
- Limestone
- Ceramic Tiles
- Terracotta
- Marble
- Travertine
- Granite
Yes they are expensive - But you get what you pay for!
We have A LOT of forum threads on these blades. They're really good blades. Many say the best you can get. Cut through tough porcelain like a hot knife through butter.
- Montolit DNA 180mm Diamond Wheel / Blade (22.2/25.4mm bore) £108.00 in stock - next day UK delivery plus Tile Cutters and Tiling Tools
- Montolit DNA 200mm Diamond Wheel / Blade (25.4/30mm bore) £114.00 in stock - next day UK delivery plus Tile Cutters and Tiling Tools
- Montolit DNA 230mm Diamond Wheel / Blade (22.2/25.4mm bore) £125.00 in stock - next day UK delivery plus Tile Cutters and Tiling Tools
- Montolit DNA 250mm Diamond Wheel / Blade (25.4/30mm bore) £135.00 in stock - next day UK delivery plus Tile Cutters and Tiling Tools
- Montolit DNA 300mm Diamond Wheel / Blade (25.4/30mm bore) £159.00 in stock - next day UK delivery plus Tile Cutters and Tiling Tools
- Montolit DNA 350mm Diamond Wheel / Blade (30mm bore) £179.00 in stock - next day UK delivery plus Tile Cutters and Tiling Tools
Here are about 20 threads on the subject. You'll see comparisons between the Montolit DNA Blades and other blades. And you'll see people favouring them, and perhaps favouring others, so you can get a good gauge on what they're able to cut and what other blades are similar etc.
Have a good read about the blades, it's competitors blades, and make your own mind up. But the DNA's will not let you down.
- dewalt standard blade v montolit dna blade
- dna blade
- DNA montolit blade
- dna blade size
- amazing montolit dna tile cutting blade
- looking forward to my DNA Montolit blade
- Need a new diamond blade
- new blade
- Best Porcelain Blade for a DeWalt?
- which diamond blade?
- Montolit DNA Blades NEW at Trade tiler.
- montolit discs
- need a new blade
- Which Blade is best?
- What blades do you use for your cutters?
- Best wet cut blade?
- Comparision tests
- Montolit DNA ??
- marcrist porcelain blades
........Yes, I have bought the blade - but I was just after some feedback from others, not specifically you, as to the performance of it, is it good on some materials and not others, etc........
Reply to Took The Plunge. in the Australia Tiling Forum area at TilersForums.com
