Discuss Travertine and adhesive? in the British & UK Tiling Forum area at TilersForums.com.
Gustyturbine
Thanks Rich. Loads of great advice. My floor has nothing like 3mm deflection over 400mm so I feel a little more confident now. I just like doing the job properly and do it once. Because I am tight probably (and lazy). Thanks again all for the great advice and I will let you know how I get on. Thanks again Rich. I owe you a beer,
Gusty.:thumbsup:
Gustyturbine
Going on slightly then. A local tiler told me that Trav should be cut with a grinder as a wet Trav tile can not be laid. Would you agree. Seems a bit dodgy to me as the adhesive is mixed with water!! As long as the tile is clean and had a wipe I would have thought that after wet cutting would be fine? Thanks.
Rich
A wet cutter will cut the trav better than a grinder but will get the stone soaking wet, this is a problem as you will not be able to get a decent bond to the back of the tile if it is wet. If you get your hands on a decent grinder disk it would save you the hassle of drying the stone before laying it. I dont use Bal (at least I haven't for a long time), I use Mapei adhesives and grouts and usually lay cement boards with Keraquick. When it comes down to grout, there are a few to choose from but if you go with Mapei, they do a grout called Ultracolor Plus. This does just about everything, really is all singing all dancing but Im afraid you will have to pick the colour you want, there are 26 to choose from :smilewinkgrin:.
As I dont use Bal I will let somebody who does tell you which products to use on that front.
widler
1,328
England
mmm,not sure about thi,i have laid many a trav floor with wet cutters,as long as you wipe excess water off(ie,its not dripping wet) it will be fine.
i have tiled a 30m2 floor,where nearly EVERY trav tile had to be cut with my big wet bench cutter,it was over 4 years ago,i still go to the farm where i laid it,not a problem at all. i would of thought that with a dry cutter, dust would of been a bigger problem than wet.
ps,don't be too hard if you don't agree,im still rough as a dog after benidorm stag do:8:
Gustyturbine
My wife has found the tiles she loves! After insisting on travertine all the time she has now gone for a ceramic tile instead. No problem at all love I said as I am out for many beers this weekend!!!!! So anyway, if I now fit ceramic do I still need a decoupling membrane? Would my cement board be fine instead? I would still use the Bal or Mapei flexible products. Thanks,
Gusty.
Rich
Im not disagreeing with the guys above, you would be fine without it as long as the floor has no bounce and I would defiantly use a cement board. But just to add, there would still be a benefit to using the decoupling membrane as well so if you have already bought the mat or still wanted to use it, it wouldn't do any harm.
Gustyturbine
Thanks guys. Out of interest I was talking to a guy that worked on T4 at Heathrow yesterday. He was telling me that they tiled straight on chipboard on battens with that heavy foot traffic! Even book stalls with some racks at over half a ton. They have not had any problems. Does it totally depend on deflection and luck? They did use flexible products though?
Rich
Bad bad bad practice. If only I had a pound for every time we heard "and never had a problem". Chipboard is not a suitable substrate to tile onto, it is not only a matter of deflection. Chipboard is very common in new buildings because it is cheap. Chipboard swells and moves with temperature/moisture/humidity to much.
Only a cowboy or somebody who doesnt know any better would tile directly onto chipboard.
Gustyturbine
So gents, now I am going for porcelaine on the floor and walls in one bathroom and trav in the other. I will 6mm hardie the floor in both. White adhesive for the trav. What tape should I use for the Hardie boards edges? Also on the walls for the trav as they are partition should I use the Hardie 500 glued and screwed? The weight would be too much otherwise.
What is the best system for sealing over a shower tray at the tile joint these days, Silicon looks bad? Any advice please,
Gusty.
Reply to Travertine and adhesive? in the British & UK Tiling Forum area at TilersForums.com
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
