Discuss Travertine and Plasterboard query. in the Canada Tile Advice area at TilersForums.com.
davebathroom
Hi, just joined, hello everyone!
I would like some advice if possible please.
I am a bathroom fitter and have a travertine job to do. The walls are 12.5mm unskimmed plasterboard screwed to 400mm centres timber with 1 noggin half way up the wall. Moisture resistant board is in the shower area which I plan to tank.
I will also seal the tiles after fitting, then after grouting.
Do you think it will be ok to use 12mm travertine(400x200 approx, honed and filled) on this board? I realise it will be close to or slightly over the 32kg sq/m recommendation.
Do I need to add any more noggins?
Thanks a lot!
Dave.
Bob Howard MBE
The boards must be rigid and I note that you are tanking the walls which is a must. The weight of Travertine tile and adhesive would be in the region of 32kgs/m2. However, be careful the market is flooded with cheap Travertine mainly cross cut which is full of voids and fillers. Travertine being a soft stone is likely to attract soap residue and dirt it is not the best finish for areas constantly in contact with water. Bob Howard MBE
Reply to Travertine and Plasterboard query. in the Canada Tile Advice area at TilersForums.com
I am refitting the bathroom, and have removed the (two layers of) tiles but unfortunately not...
6K
Hi been browsing the forum, lots of good advice. I’m after some myself of you don’t mind...
Hello all. I'm doing a total refit of my bathroom, including the floor which is water damaged...
Hi, We have brought 600 x 400 x 12 travertine for wall and floor in a small bathroom. The...
5K
swanman
L
Right, I'm going to get shot down asking such a question. I'm doing 2 bathrooms in a house...
10K
p4ulo
    Votes: 5 4.7%
    Votes: 8 7.5%
    Votes: 6 5.6%
    Votes: 29 27.1%
    Votes: 14 13.1%
    Votes: 27 25.2%
    Votes: 3 2.8%
    Votes: 2 1.9%
    Votes: 19 17.8%
    Votes: 18 16.8%
    Votes: 13 12.1%
    Votes: 5 4.7%
    Votes: 3 2.8%
    Votes: 1 0.9%
