Travertine walls tiles: Advice for DIYer
Gazz
Hello
First time poster, but have done a lot of reading and picked up a LOT of tips from the forum: thanks.
I'm a reasonably good (if slow) DIYer. I am fitting a new bathroom suite and was going to ceramic tile, but have bitten the bullet and bought travertine which I think will look classier once done.
The bathroom is pretty small, a 1930's semi, solid/lat walls (no plasterboard) & I'm looking to half tile except for the wall which runs the length of the bath which I want to do full height and make a feature, mixing in some mosaic.
Problem is on this wall in particular, I'm paranoid about the weight of the travertine (about 30Kg/m2). Various individuals at a few shops have said it'll be fine, just fix over the plastered wall (solid external brick wall). However having read a bit about the loads involved I've bought some HardiBacker for this wall only, but have the following questions:
1. I,m going to lat the wall with 2" X 1.5" wood, fixing this vertically to the existing brick wall using screws & rawplugs. What centres should I use & what size screws/plugs would you recommend.
2. I'll fix the backerboard to the wood lats using 40mm aquapanel ceramic screws: all I could get: will these be OK? Is it best to tile onto the rougher side of the backerboard, or smoth side?
3. I'll fix the tiles to the backerboard😀o I need to prime this with anything before fixing the travetine (probably going to use Mapei cement based powder adhesive).
If I do the above, do I need to be concerned about the weight issue.
With regard to the half tiled walls. I've removed all paint and stripped these back to the bare finish plaster. The plaster is solid and as it's half tiled I'm not quite so paranoid about the weight concerns. However:
4. Do I need to prime these before tiling and if so with what?
I'd be grateful for any advice.
Gazz
Just curious, but why are you only boarding out the one wall? It's still the same weight/square metre on the walls that are only being half tiled!?!
I'm pretty sure that the walls will generally hold the weight of the tiles, as I said they are solid, not plasterboard and in good condition. (please correct me if I'm wide of the mark here) However I am a little paranoid (perhaps unjustifiably) about the one wall where I will be tiling to ceiling height. A tile falling on your toe is one thing, but a tile falling on your head whilst sat in a bath is something else completely!
Perhaps I'm going overboard, but I'm concious that the "chain" is only as strong as the weakest link, hence I would like to get things right from the safety aspect.
Gazz
Gazz
I don't think you're going overboard at all. The weakest link in your chain is that Plaster is only rated to take 20kg/m². :thumbsup:
Beanz
thanks for the response.
For the half tiled walls then should I be strapping these and using hardibacker, as I have for the main fully tiled wall. The problem would then be that the wooden lats, plus hardibacker, plus the tile thickness would bring the lower part of the wall out by around 2.5 inches.
Just thinking of the physics, is it not the case that a fully plastered wall would effectively be self supporting where the load is partially applied ie the load is downward (gravity): as I am only tiling the bottom half of a fully plastered wall, would the adhesion of the plaster "sheet" above the tiles not contribute to the overall resistance to the downward pull of the tiles. Just thinking aloud.
Gazz
I agree, that would look more than a little odd.. :yikes:
Have you thought about taking the plaster back to the block/brick and dot & dabbing Plasterboard? Bare Plasterboard can take 32kg/m².
No idea about the Physics of it really, and how the forces work, but hopefully someone on here will know a little more about that side of things. I've seen Travertine tiles put up with tubbed gear on Plaster a year ago that are still standing, but would i recommend it??? Nope. :thumbsup:
Cheers Beanz
Can anyone else offer any advice/opinion/solution to this and also advice re my original questions in the first post.
Gazz
Cheers Beanz
Gazz
Having just read your post carefully, I must tell you that you will be greatly overloading the plaster wall if you want to fix Travertine to it. Plaster is only "safe" up to 20kg/m2 and that includes adhesive and grout. There is a good chance your tiles will be 25 -30kg/ms alone before adding adhesive and grout. This is something you need to consider carefully before you proceed. tilersforums.com CAN NOT CONDONE OVERLOADING SUBSTRATES WITH INAPPROPRIATE TILES.
Further to your question, it is necessary to prime the plaster with and acrylic primer before tiling if using a cement based adhesive.
Grumpy
Thanks for this. I realise that you are quoting the recommended stresses but do wonder what these are based on (curiousity, not trying to be a clever arse).
Surely the wall overall area, tiled area and tile location must also be considered.
For example, take a plastered wall say 10m by 10 m and travertine weighing 30kg per square metre. There would surely be a vast difference in the forces exerted on the plaster if for example you tiled the full 10 x 10 sq metres, as opposed to, say, tiling an area of that wall 10cm by 10cm. The 10 cm square would be the same weight per square metre, but the total force on the wall (plaster "sheet") would be only 0.3Kg, compared withthe total force exerted on the fully tiled 10m by 10 m wall of 3000Kg.
Equally if the same wall was tiled for the top 5 linear metres only, there would be an unsupported force of 1500Kg. However if the wall was tiled from the bottom up for the first 5 metres, the tiles would have the same weight, but as you are starting from the floor, and assuming that the gravititational pull is downward, there is surely an element of support from the floor boards which in turn sit on the joists.
This is why I was questioning the safety of half tiling (about 900 cm floor upwards) on the plastered wall (I will be using a backer board when I tile the full wall).
Please don't take this the wrong way, I'm not some sort of physicist, nor am I trying to be a clever arse: just trying to understand the logic behind the quoted figures.
Many thanks to you and Beanz for your replies.
Gazz
Gazz, there should be an expansion gap at the bottom, the tiles don't sit on the floor. I can see what you are saying though, and watch this thread with interest. :thumbsup:
Gazz,
DHTiling,
Gazz,
DHTiling,
