tricky cuts in 12mm ceramic floor tiles
You can always use a a piece of plumbers solder and mold to the shape of the loo base etc, then use this as template. I find this a bit easy than paper.
BUt try both and see what does it for you ?
Nige
sounds like a clever little technique, will try it out next time
- - - Updated - - -
Nige
god this is an old thread. Just another suggestion for cutting door frames though: If you lie a spirit level across the closest laid tiles to the frame and have the level across the front of the frame you can mark underneath with a pencil and the line should follow the projection of the tiles perfectly
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
