brian c
the cutters are ok for quickly cutting plastic trim but no use for mitre cuts...imo....so i use a hacksaw and mitre box for mitres and cutter for straight cuts with plastic trims.
Hardly worth using a separate tool for straight cuts is it?the cutters are ok for quickly cutting plastic trim but no use for mitre cuts...imo....so i use a hacksaw and mitre box for mitres and cutter for straight cuts with plastic trims.
In that case, might try both. Today I bought a plastic mitre block from Screwfix but none of my hacksaws nor the ones I could find today were tall enough to clear the block. Ideally I could order a mini block online, but I preferably need it now.I have both in my toolbox. The snips are fine for somethings, and not for others. I use both tools as much as each other, and find I can get an excellent finish from both.
Sorry no idea, why not get a hacksaw and mitrebox instead, much better finish, i find the trim cutters crush the trim.
That's also good to know. Just goes to show I need to try the snippers to decide whether they can work for me. As I said earlier I now have not a blue but black butchered box, but you can still cut straight lines through it.I use the plastic cutter most of the time and finish it off with a sharp stanley blade
Try both methods, which ever suits, use that method.:santa_cheesy:
The trim cutters are fine , but i find a hacksaw and a mitre box a lot easier....and om metal trims i use a file as well to dress the cut edge smooth..
You could also use a file on plastic trim to tidy mitres up etc...
Those plasplug ones do very flimsy though....if you deffo want a pair of cutters then buy these ones>>>>>> TradeTiler.Ltd Plastic Trims and related tools
you will se a good quality mitrbox and hacksaw there as well....
