Guest viewing is limited
Tiling Tool Suppliers
Discuss trim cutters?? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
The_Master
apart from mitre block and hacksaw,whats the best tool for cutting a trim.bought a plasplugs one from b&q-crap-cuts curvy!!..£10 anall+cant find receipt.looked at the one on tradetiler site.looks good.has anyone used it or out else??
i use a good solid wooden Mitre Block with hacksaw, dont know if id trrust the trim cutter, although im always open to new toys to make the job easier, and call me crazy but just bought a dremel to help me shave down the metal trims if the corners for boxing in, windows etc arent exactely square, top notch finish. Plastic trims cut with the mitre block and tidied up with the knife, Probably just as fast as the trim cutter, i may be wrong as ive never used one, but do the trim cutters not mishape a plastic trim with the pressure applied when cutting? just curious!!
grumpygrouter
they do cut both ways just need to cut flat side down with scissors first
Got to say I can't see passed a mitre block and hacksaw as posted previously by a number of people. Currently using a little plastic disposable thing that has holes in the bottom for screwing down securely. Didn't even have to buy it, a friend gave it to me. Best value piece of kit i've got!
Grumpy
Reply to trim cutters?? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Can you tell me what the best mitre cutter out there for cutting chrome tile trims. Is there a...
Hi guys, i took some jobs as a contractor for some MC Donald's restaurants but i find it quite...
Hello! I am new here but I have been reading a lot about manual tile cutters on the forum. I am...
28K
L
    • Winner
Eventually bit bullet after 22 years in the game and bought one of these. Cut off/mitre saw KGS...
7K
Hi All, I'm looking for a tile cutter for DIY use. I've spotted this one and wondered if it is...
10K
Derbylad
Popular Tile Cutter Threads
trim cutters??
    Votes: 5 5.9%
    Votes: 6 7.1%
    Votes: 5 5.9%
    Votes: 22 25.9%
    Votes: 13 15.3%
    Votes: 25 29.4%
    Votes: 3 3.5%
    Votes: 2 2.4%
    Votes: 18 21.2%
    Votes: 14 16.5%
    Votes: 6 7.1%
    Votes: 5 5.9%
    Votes: 3 3.5%
