Trowel advice for porcelain.
2020Tiling
hi tilers !!! thanks for your comments on my photos ! iam am in the process of learning the art of 3 way mitres ! .. the question i have is about this glazed porclin job iam starting on sat! the tiles are 600 by 300 , the floor is curently floor boards which i have converted the customer from wanting to ply it himself :thumbsdown: to letting me lay no more ply down :thumbsup:
was wondering wot you size trowel you would recomend for laying them ? its my first porclin job and do i need to butter the back of the tile aswell as the floor ? also as ive never used no more ply yet ,is it going to get a good bond on floor boards ? as iam hearing the screws you get with no more ply is just ment to hold the board down while glue sets ? :dizzy2:
I have never used No More Ply but I am sure Smurf will be along in a minute to give his vast knowledge on all things NMP. As for the trowel size, I use a 20mm half round thick bed/solid bed trowel. Fx a tile after trowelling the floor then lift to check for coverage. if it is 100% then you are fine, if not then try back skimming too.
You should only really have to back skim if the backs of the tiles have deeper than usual ridges which will fill with adhesive when tiles are fixed:thumbsup:
as I was going to say Russ ad verbatim!:thumbsup:
2020Tiling,
grumpygrouter,
2020Tiling,
grumpygrouter,
