Discuss Type of Primer in the Canada Tile Advice area at TilersForums.com.
L
LM
I will certainly take your advice on the adhesive and I will try my hardest to remove the paint. On the same point the other walls are plastered (new) would you prime these if so with what primer. Lee Mac what is a C2TE adhesive.
I don't know what brands you have available but I'm a big fan of Ardex/BAL products, other products may be just as good it depends on what's available to you and at what price. Different primers and adhesives are made up of and differ in qualities.
You need an acrylic primer like the one in the link below
ARDEX P 51 Primer - http://www.ardex.co.uk/ProductDetail.aspx?ProductID=6&CatID=1
Hopefully this link will help you understand the different adhesive classifications as well.
https://www.bal-adhesives.com/wp-content/uploads/2015/07/BAL-Adhesives-Training.pdf
C2TE is the standard and most common powdered adhesive used for most wall tiling. :)
Reply to Type of Primer in the Canada Tile Advice area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
    • Friendly
Some adhesives give info (not seemingly Mapei). I think the Mapei Standard Set Plus would suit...
Tilers Forums on FB
