Discuss ufh failure in the Canada Tile Advice area at TilersForums.com.
merit
493
had a call from a client id done a bathroom for a while ago, ufh not working,he said he hadnt commisioned it because of the nice weather ect, anyways no heat coming through, he asked if i had nicked the cable, couldnt of because it was slc over full area,he asks can i take a tile up cos the electrician knows exactly where the problem might be,ok but might damage surrounding tiles getting it out ect,turns out the electrician has cut the matt to suit the floor and taped the probe to the end,so he is going to leave it ?
merit
493
like i said, ufh was down to the spark, he tested it , layed it , then cut it to suit ?
then wonders why it dont work,i asked the client to make sure he tested it before install, i wouldnt have slc otherwise, client just gunna live with it,i wouldnt id want it back up at sparks expense/must have cut the sensor end
bugs183
What was the sparky thinking, what a div.
Try this bloke, he'll tell you if this floor is salvagable, and if it is get him in: Steve Ashby, 07989 382218.
He's an expert in repairing electric under floor heating. He's not cheap, but i used him on a job that failed (my fein Multimaster's fault, honestly, not mine). He located the problem down to the tile. He took the tile out, reconntected the fault. Also if he does the work some manufacturers will still validate the warranty. Very very impressive.
Good luck!
This is one reason I will not install ufh and always tell the customer that the ufh must be tested before I carry out any tiling, to be honest I hate tiling onto ufh anything goes wrong the tiler will always be the first one to blame,Ive never had a problem yet but law of averages it might happen
Honestly Afright, they really aren't too bad. Just make sure you do the work, get a sparky to check, but don't let them any where near fitting it! A multi meter and an alarm is all you need, quite simple really after a bit of practise.
I have fitted them I know there easy to do but just rather not, do not want the responsibility if it goes wrong would not want the big expense of putting it right.
Reply to ufh failure in the Canada Tile Advice area at TilersForums.com
Ok so just putting this out there for a mate of mine to see if anyone would like to take on...
Spare Tool
Today I had to replace a cracked tile. The customer said there was UFH under the tiles. I...
Marvo
Got onsite yesterday to find that the builder had laid the UFH mat, then covered it in SLC. I...
The dread strikes when the number of a customer appears on your phone several months after you...
Hi guys, I am after some advice from the pros, so figured id ask here. in my new extension...
6K
ufh failure
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
