Discuss Underfloor Heating Questions in the UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Hi 1 How long does the screed need to dry out . It has been laid onto a wet pipe system?
2 Does the heating system need to be "fired up" before tiles are laid?
3Can Hardibacker be used on top of a ply floor that has a piped underfloor heating system underneath?
4Can a 2mm grout joint be used on 600x600 porcelain floor tiles?
Sorry about the random questions
1depends on the screed type. Sand cement approx 6 weeks. Anhydrite can be force dried.
2 yes. 21 days for sand cement but don't use the heating to force dry the screed. 7 days with anhydrite, deffo use it to force dry the screed
3 yes but it will slightly impare the efficiency. Be careful how you fix it.
4 probably but he tilers should answer hat one. bear in mind the joint pattern to form your tile bays. Not sure you can do a 2 mm joint.
Gazzer
Over a year old thread Alan, but good info anyway.
Reply to Underfloor Heating Questions in the UK Tiling Forum area at TilersForums.com
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
We had a water underfloor heating installed and tiled over. 3 months later we noticed many tiles...
Amethsyt
TF Group Please Join
