underfloor heating.
The foil won't be much help as it reflects light. Underfloor heating works initially through conduction, from the wire/pipe into the finish layer. This then emits heat through transfer to air and a little light wave energy.
Therefore to get the most heat into the room, You need a good dense mass above the element, this will give better heat transfer to the room and the thicker the insulation mass under the element, it will loose less heat downwards.
Sorry for going all technical!
I will now give my opinion on your situation...... Forget the foil idea straight away! Prime the floor with an acrylic primer and fix 10mm insulation boards using bagged cement tile adhesive. An easy, recommended and trouble free installation. Sorted!
As for SLC, any quality fibre reinforced bagged SLC poured evenly over the floor and floated carefully will leave a level smooth finish
Thanks. This is what I want to do - however it will take this floor above the adjacent floor which is sculptured porcelain tiles. These really could do with covering as the floor is the result of 3 different room extensions. What is the best way of covering these tiles, I thought of vinyl over hardboard or thin ply as I cant go direct on to the tiles because of the ridges in their pattern. Or should I just self level again? This job is getting like pinoccios nose!
Thank you for taking the time to reply - interesting
Hi. I am a keen DIY enthusiast over many years. Came to this site when researching UFH. One job I did not enjoy previously was using self levelling compound - it did not level! maybe too thick? However as I am thinking of laying UFH loose cable I will need to use it so any tips would be appreciated. Also, has anyone ever recommended using al. foil under 6mm insulation board to increase the insulation but keeping low height of thickness? Would this be dangerous and make the wire overheat etc?? would be working on concrete base.
Welcome to the forum. 🙂
Yeah as above. SLC is more of a push it around and it'll sort its self out kinda stuff.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
