uneven floorboards
Hello peeps just a quick question:
Looked at job today, bathroom floor 5m, floorboards, solid but big dip in centre.
Can i fix Durabase to them and SLC over the top?
Cheers, Jamie.
If they are just uneven that is fine but if they have sagged as a result of wet rot softening them or wood worm etc etc.... All possibilities in old houses then it may be that adding the extra weight of a tiled floor will cause problems. I would just chek it out first. I would also everley the floor boards with 6mm hardibacker or similar before tiling. A it's a bathroom I might also be tempted to tank
Am trying to keep height down to a minimum, If it is just uneven joists can I not just install the Durabase? If not I just want to know the reasons, it's not a wet room either so I don't see the need for tanking.
It's not about keeping the height down its about installing a tiled floor on a timber floor which has "sagged" that sagging could be due to many things but they include, creep, over loading and rot. If these are issues your floor could collapse. It would be unwise and in the worst case scenario downright dangerous to tile this floor without knowin why it has sagged. Just my opinion ..... Perhaps you will get a different answer from others.
He's right Js.
If you take on this floor you inherit any problems that may come with it. Woods a bad enough substrate to fix on, let alone with any sagging or age etc.
Old floors are often out of level from one side to the other, but sagging is showing that something isn't right with the floor.
Get it properly checked out for doing anything, a customer can soon point the finger if you don't.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 2 1.2%
    Votes: 5 2.9%
