bigd
Hi, my bathroom has the usual green chipboard floor which has a dip in it of up to 10mm due to a couple of low joists which appear to have been like that since the house was built 17 years ago and not movement.
I'm looking to use 6mm cement boards as a base for tiling but want to start with a flat surface under them, would an SPF adhesive like Keraflex Maxi be ok for this? I'd then use the same adhesive on top to lay the tiles. I have put a ton of extra screws into the floor already and it doesn't seem to bounce at all, glass of water on floor, jump up and down etc.
The floor is flat in the other direction but does run off from one side to the other which i am fine with but means I don't want to use a product that will run like SLC. Replacing the floor isn't possible due to walls running across the floor and the door is at the low point and I don't want to raise it that much.
Any help appreciated as always.
