jond500
Hi All,
I'm just about to tile my bathroom and am working with much bigger tiles than I have used before and am looking to get a better tile saw than I have currently (a cheap DIY thing)
I have looked into hiring one and have decided to spend the money on buying one as the costs will be similar and I will have a tool for life as it won't do a huge amount of work as it will just be used at home for DIY, I have looked around and found this one which looks the part and seems to have good reviews:
Vitrex - QEP Pro-750 Wet Saw / Tile Cutter (select voltage) £0.00 in stock - next day UK delivery
The cuts it will be doing almost exclusively on my bathroom will be cutting the corner mitres, the tiles I am using are 500mmx200mm and it will be the 200mm width getting mitred, the tiles are 8mm thick and I think ceramic.
I am also using iridescent mosaic tiles for the feature wall, well a strip of 300mmx300mm from floor to ceiling, will this cutter be able to cut these or will I need a different blade?
Cheers for the advice.
Jon.
Jon.
