Discuss vitrified? in the British & UK Tiling Forum area at TilersForums.com.
You have a helper? Ok for some.....Hi Negsey,
i normally put marble down with slow set white flexi adhesive,doesn't have to be flexi but i find it sticks better,white because grey can show through tiles some times or so i was told.Slow set because i like to keep people off the tiles for a day or two,this helps when you go to seal too,i was actually using mapeker white rapid set today,real good stuff but the floor wasn't too level so i fought hard all day,my helper was busy mixing and cutting,lol.
The sealer i use is Lithofin stain stop MN, a good impregnator.
i see. a customer has asked me to lay some travertine floor tiles and i have not worked with natural stone before. not sure about the sealing side of things and i have not seen the tiles he has gone out and bought.what about adhesive and grout? i take it normal rules apply as its going onto a concrete floor?
Has to be a white adhesive, so it doesn't bleed through. The adhesive has to be polymer modified. Use a flexible grout aswell. In terms of sealing, you should be fine to fix, then seal, then grout, then seal again and maybe one more time. Make sure also that you back-butter the tiles to fill in any voids in the travertine, as these holes in the back will soon appear on the face of the tile if you don't. If it is a large format tile, then use a large format trowel.
Don't take this the wrong way, how long have you been tiling and where did you learn. Again, don't take this the wrong way, just interested to know
Reply to vitrified? in the British & UK Tiling Forum area at TilersForums.com
